  New Posts New Posts RSS Feed - Refinishin wood swim platform
sweet77 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sweet77 Quote  Post ReplyReply Direct Link To This Post Posted: April-23-2011 at 2:34am
Originally posted by malcolm2 malcolm2 wrote:
OK, I am here to learn, so tell me the problem with silicone, and the benefits of the other stuff you suggested. Again, I have lags and screws, so it will not be difficult to "fix" my screw up...Unless I get the word that I need to replace the lags with nuts and bolts. Let the teaching begin.
Silicone does not belong below the waterline.
3M Marine Adhesives and Sealants
Malcolm,
Have you ever been able to literally peel silicone off a surface? Silicone bathtub caulking is a good example but it holds true with any of the silicones. It's adhesion is poor! The only place it's good for is when it's between two surfaces/flanges like a subsitute for a gasket and even then I'd suggest something like Permatex! Yes, you can say the platform brackets against the transom are two surfaces but the bolts and their holes are not. If there was a silicone under the brackets originally, I'd say most of it you were able to peel off. Try to get 5200 or 4200 off and you'll see the difference.
I hate silicone!!!
There are some types i dont mind
76 Nautique
"If you do what you always did,You'll get what you always got!"
"An empty wagon makes t
88 S NAUTIQUE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 88 S NAUTIQUE Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2011 at 10:16pm
If you put oo much oil on the platform and it is still sticky the next day, wipe it down with straight mineral spirits. Will dry with the nice unshiny yet smooth look you want. Went into panic mode when my platform was shiny and still sticky 24 hrs. later!
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 1:04pm
Oil finishes were meant to be "Rubbed-In".
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 1:38pm
Exactly, excess will simply not get absorbed and will gel on the surface.
Here's a trick that I may take some heat for but I cut my first 2 coats of oil with a little mineral spirits to make it thinner. I feel it penetrates the old wood deeper. After 2 coats I then apply oil straight from the bottle. I always brush on, wait 5 minutes, rub in. I try to go at least a few days and more when I have the time, between coats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 2:01pm
Alan,
You won't get any heat from me!!! In fact, I wouldn't be surprised that the first CPES was made by someone familiar with wood finishes and had done plenty of varnishing bright work!
BTW, tung oil and Teak oil finishes always state on the can that you do not leave any on the surface!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 2:19pm
[/QUOTE]
Thanks Pete, Don't know why I love coming back to this thread.
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 2:37pm
[/QUOTE]
Now I see why this thread is still alive. There's just not much left to say about oiling yer teak...
1973 Skier
IAughtNaut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IAughtNaut Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 3:23pm
Apparently I need to be more careful when browsing these forums at work...
bring the ruckus
2000 Pro Air
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 4:30pm
LMOA!!!!
mdvalant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvalant Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 5:43pm
Same here...Almost got busted.
Can I share my teak job?
'90 Ski (sold)
'00 Sport
skutsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 6:17pm
Mike, you obviously have a better camera then me, but that color looks pretty close to mine. What product did you use?
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvalant Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 6:22pm
Our platform was in pretty good shape, just dry. So...I just slapped some of this on it. (we have been using the same stuff for years) Love the color it brings. Coat two went on the top last night...not sure if it'll need another one or not.
'90 Ski (sold)
'00 Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote skutsch Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 6:26pm
That makes sense, I used the Teak Oil Sealer from Starbrite, that must be why the color is similar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvalant Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 6:32pm
We used the sealer on the 90. Worked great for a long time but now it's starting to come up in a couple places, by come up I mean look patchy I guess. I'd love to strip it and re-teak oil it.
'90 Ski (sold)
'00 Sport
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 6:33pm
Ive actually found that the type of teak oil has very little effect on the platform color. Ive used Star Brite and Amazon and could not tell a difference. Ive even tried a magic blend of teak oil, boiled linseed oil and Automatic Transmission Fluid in an attempt to darken mine... and it didnt do a thing.
I think the color of your teak is the color of your teak, and theres little you can do to change it (at least by oiling it). Each platform will be slightly different. My '90 is very light in color, our BFN is very dark, and my dad's '03 is a medium orangy-red. We put the same oil on all of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvalant Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 6:45pm
Had a pair of my favorite Cypress Gardens Mustang combo skis in the ski locker of a buddy's sport. His tranny was leaking a smidge and the water/oil soaked my skis for a while without our knowledge. Best thing to ever happen to the skis. They look new and are super waterproof lol
Oh and the boats fixed too.
'90 Ski (sold)
'00 Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-04-2011 at 9:07pm
Tim,
West brand does have a "dark" version. I have a bottle of it and it does darken the Teak. This is good especially if you have gone through the complete cleaning process which includes the "brightener". Also, aniline dye powders for oil based finishes are available for tinting. Aniline dye powder at Woodworker supply
NC_Tique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC_Tique Quote  Post ReplyReply Direct Link To This Post Posted: May-15-2011 at 12:15am
I just put one full coat on mine today. A pressure washer was my choice of cleaning. I put it in the sun today and it soaked up a 1/3 a bottle or starbite teak oil. Mine looks dark but lighten up as it dried.
It is going to look sweet on the boat. I'm ready for the water!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2011 at 2:53pm
been working on my platform while I find the time to fix the prop and shaft..
Its been cold, rainy and windy..normal fall weather..so i´m not in a hurry to have the boat in the water...
Total of 5 coats on each side...
Jllogan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: June-06-2011 at 3:55pm
I used the starbrite teak oil restoration kit and it worked awesome. You should have seen the dirt and filth coming off after I used the cleaning step. It really brought it back to life but I used the whole bottle of teak oil and had to buy another, a total of 6 coats. Its been holding for a few weeks. I will probably give it one more again before I take it out.
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2011 at 2:00am
I just put on coat # 7 My question is can I coat it once a month till I put the boat away in the fall? If I follow this schedule can I just maintain it and never have to clean it again?
1987 Ski Nautique
Polar Express View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Polar Express Quote  Post ReplyReply Direct Link To This Post Posted: June-27-2011 at 11:49pm
Thanks for all the pics and specific product results. Wish I found this thread a few weeks ago. I used the Te-Ka brand stripper and brightener, and I LOVED how that worked. The problem is that I chose the Daily's hard-drying teak oil. While it looks just gorgeous in the garage, I do fear it's going to lift and such over the season. I'm not planning on stripping it off for this season (yet) but even before finding this forum and thread, after seeing the completed result, I was wishing I had chosen a true 'oil'. I could certainly see a use for the Daily's product (I'm not ripping it) just not for a swim step.
Also, my swim step is the more trapezoid shape, with no open slots in it, and the underside is separating and cracking. I actually expect to have to rebuild it soon, maybe this coming winter.
Live and learn,
PE
1996 Sport Nautique
This is America, if you don't like it, go conquer another country, and start your own.
I'll keep my God, my guns and my freedom, Barry can keep his 'change'
