23' Fish Nautique Restoration Project |
Page <1 14151617> |
jzarski ![]() Senior Member ![]() Joined: August-12-2010 Status: Offline Points: 180 |
Well I am still working on the boat. She is pretty much done. Here are a few pics
You do nice work sir! When is the maiden voyage?
As soon as the wind dies down here on the east coat of FL. It's blowing 25 MPH
kapla ![]() Grand Poobah ![]() ![]() Joined: March-27-2008 Location: BA, Argentina Status: Offline Points: 6148 |
nice tower!!! no speaker or board racks!!!
nice work there john! |
aquatop ![]() Newbie ![]() Joined: November-09-2011 Status: Offline Points: 1 |
A question about how you reinforce the outboard bracket to the transom. Did you have to thicken the interior before bolting on the bracket? If so how was it done and how thick with what material. The 300hp yamaha must weight close to 600lbs and the fish nautique was not design for an outboard but I have one and want to put on a similar heavy outboard on mine. I have an Armstrong V shape bracket and wanted to install but saw that the exterior skin is only 1/2-3/4" thick and the interior skin is much thinner.
Aquatop
First, welcome to CCfan. Are you putting this outboard on a Fish? We'd sure love to see some pictures! Second, take some time and go through John's complete thread on his rebuild. You will then find what he did to reinforce the transom. Third, ![]() Fouth, if you do infact have a Fish, make sure you get some pictures and text submitted for the diaries section. Not to many Fish's around so it would be a fantastic addition. |
Awesome job John! I just went back and looked at the pictures at the start of your thread,really a transformation.
Thank you Gary, I am hoping to have some professional pictures in a few days of the inside and outside. As soon as I get them I will post them for everyone to see. She has only been wet once. It ran ok, the carb is in bad shape so I bought a new one and need to put it on. I will keep everyone posted!!
John |
Calling all you motor heads.. I need help
![]() The motor in the Fish is an 81 351W serial #212936 Model # PRD WR R10. PCM says this is a Right hand rotation motor. Does this mean that it truley turns opp. of a car? If so, is the cam also a right hand cam? I am asking this so I can try and get the motor running right. I have had the boat in the water a few times and I can't get the motor over 3000RPM without it falling on its face. I just put a brand new in the box Holly marine Carb on it and I am still having the same issue. The timing is spot on and the dist. is also brand new. Coil seems to be fine but I have not changed that yet. Wanted to try and pick a few brains here before I just keep spending a bunch a money on things that are not bad. Thank you all in advance. JOhn |
Jllogan ![]() Platinum Member ![]() ![]() Joined: May-18-2011 Location: canton, OH Status: Offline Points: 1728 |
this may be a dumb question but did you adjust the carb? Same thing on the dizzy is the dwell/gap set correctly?
Gas flow restriction? Check fuel pickup, anti-sihpon valve, filter, maybe even pump.
Correct, yes, and yes. R = RH. Im not sure what this has to do with getting your engine running properly though.
I would have started asking questions before starting to throw parts (and money) at the problem, but I guess better late than never. ![]() Before we can help, you'll need to give us some background info and some more details: 1. What transmission do you have in the boat (presumably a Velvet Drive 1:1)? 2. What prop are you running? 3. Describe how the boat runs. Does it come out of the hole strong and run right up to 3000 RPM? Does it run at a higher RPM momentarily and degrade to that level? Or is it doggy all the time and never gets above 3k? 4. What size and style Holley did you put on the boat? 5. Describe "perfect timing". Did you check the base? The advance? What did you get for total timing (at 3k RPM)? 6. Have you verified the firing order? What is it? |
tuna_tugger ![]() Senior Member ![]() Joined: February-28-2010 Location: Los Cabos, MX Status: Offline Points: 105 |
John, you have done a great restoration to the boat but the motor is a pain in the ass to get set upight. Yer it is a reverse rotation motor. I tried the Holly carb. and it lasted a while the lots of problem and the carb. mechanic down here didn't so I put an elenbroch and it runs fine. The oly other change I made was electronic ignition. I set the timming to +6 deg. and run regular gas with a bottel or two of octaine buster and no pinging.
Have you weighted the boat now that it is rigged? After watching about 3/4 of your rebuild I decided to sell the boat because I don't have the time and I'm to old. Plus it used to much gas to use it for charter. We still have a 23' ponga with a 100 HP 4stroke so it payes for it self and I still catch some great fish. Good luck. |
Don Liberman
A plus
ultrarunner ![]() Platinum Member ![]() ![]() Joined: October-02-2005 Location: Ridgefield, Ct. Status: Offline Points: 1811 |
Did you have the tower powder-coated, or is it painted? It looks really sharp!
Its all powder coated. Thank you. I do like it alot better then the Alum look
taylor114 ![]() Newbie ![]() Joined: January-23-2012 Status: Offline Points: 3 |
hi
your boat project is amazing. im redoing the engine compartment currently. need to put new steering in. i know about the 10.5" throw on the correct craft unit. did you re-install this or do hydraulic? how does your turn at slow speeds? would love to hear what you think is the best option. thanks taylor |
Hey Taylor, I went with Hydraulic. It doesn't turn very good at slow speeds but if you hit the throttle a bit and back it down it respondeds well. I am not a fan of the teleflex steering systems, so I am not a good person to ask about whats better. I also went Hydro because I have another steering station in the tower. Love to see some pictures of your boat!!! John |
hey John!
did you finish the boat? pics? water test? fishing? lol |
Hello everyone. I am in need of some transmission help. I had the tranny in my boat rebuild and have been taking it out when I get time. The other day I put the new prop on and wanted to see if she was dialed in. Well she is dialed in.... 4400RPM 41MPH on the GPS. I am so happy. Well to the issue. Backed her down to 3500 and was crusing when the the boat jerked and we lost forward. Tranny fluid all over the bildge. Took the motor and tranny and to find the front seal popped out???? What causes this. I took it back to the oerson that rebuild it but I don't want to get the run around so I am asking you all what should he tell me???
John |
John,
The front seal popped because of a bad rebuild. You just can't put in a new clutch pack and say it's good. That front seal does not see any pressure if the pump is good. You didn't send it to FFM did you!!! You sent it to someone who thinks he knows about rebuilding but should stay in the back yard!! |
John,
The front seal problem is well documented in past threads. Sorry to hear about the problem. |
No clue who FFM is???? But no I had it done by a local shop who said they could do it...... This sucks!! I am suspose to have the boat in the Keys for a week in May. Any suggestions on someone in the central florida area to do the job right????? John ![]() |
FFM is fantastic finish marine and CCfan's best trans expert Eric Lavine. You need to spend more time reading other threads here! ![]() ![]() ![]() |
It will cost a fortune to ship that heavy little thing. I am doing a search now. :)
Luchog ![]() Grand Poobah ![]() ![]() Joined: April-17-2007 Location: Argentina Status: Offline Points: 2135 |
Pete you're not paying too much attention to some threads... but Eric's no longer in FFM or the trans repair bussines.
I dont know if he would do one for a CCFAN though. |
I have been paying very close attention to what happened at FFM. In fact, Eric and I have had several PM's on the subject. He is still involved in FFM and does go in to FFM several times a week to see how his new owner is doing. It was a former employee and per Eric is as competent as himself. I tried to phrase my comment above in a way that didn't directly connect Eric with FFM but I guess I failed! ![]() |
Not really. It will fit into a plastic milk crate that you screw a plywood top to. Then, it will go UPS or FedEx. Many many here have done it. Like I said, you need to look at some of the other threads here on CCfan! ![]() BTW, one of the threads was regarding a member in Florida who got stung real bad by a local shop who said they could do a rebuild. It turned out this shop was real "back yard" as well and his trans blew the front seal. They "rebuilt" it again and it blew again. The member sent it up to FFM and they did a proper rebuild. |
Fl Inboards ![]() Grand Poobah ![]() ![]() Joined: January-20-2008 Location: United States Status: Offline Points: 2082 |
Call Art Cozier in Orlando, I we have a number of exchange Units that Art re-builds for us here at Florida Inboards Inc. FFM Is also a great place to go but then again the shipping on a Borg unit can get rather expensive. I send all my V-drive Hurth stuff Dr.Levine and would send the Borg their to, it is just that the Borgs are rather simple unit and Art can do them blindfolded. PM me if you want Arts contact info or you can contact him at acozier@nautique.com |
Well it looks like the pump was bad. It was not replaced in the rebuild, so I have one on order and my trany guy is doing it for me. Not the fault of anyone in my opion. Yeah he should of told me to replace the pump but at the same time I should have researched it a little more. Anyways should be back in over the weekend.
John |
Page <1 14151617> |
