  New Posts New Posts RSS Feed - 86 barefoot floor replacement
 Post Reply Post Reply Page   123 4>
shane krausser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shane krausser Quote  Post ReplyReply Direct Link To This Post Topic: 86 barefoot floor replacement
    Posted: January-03-2012 at 2:32pm
So here we are setting into a slight winter in Florida. After enjoying some summer boarding i am ready to go demolition on this floor. I have read up on quite a few threads and have seen some outstanding work done as seen in some photos. As i am very familiar with carpentry and mechanically inclined it never hurts to hear whats been done and proven. I am going all composite, most likely a high density foam composite with the floor so no talking wood for me!! Any feedback is nice, i did see some hull stands on a few threads and i was curious as to when i should use them with the boat being worked upon on the trailer. Happy new year!
86 Barefoot Nautique 496
Jllogan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: January-03-2012 at 3:15pm
Welcome and good luck! Any pics?
The general consensus is that the boat should be up on stands when the stringers come out. You can tell that your weight will bow the hull in spots so the assumption is the trailer bunk could deform it inward. I dont think it is necessary until they come out but wouldnt hurt to do that first if you arent planning on moving it. Good idea on the composite, I would have if the budget woudl have allowed. What kind of composite? not all kinds are suitable. A few on this site have used coosa.
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: January-03-2012 at 5:10pm
Welcome here on CCF!
Lots of info to be found here...
If you wanna do compsite style, I too would recommend coosa.
Good luck! And we do love pictures here
Post Options Post Options   Thanks (0) Thanks(0)   Quote shane krausser Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2012 at 1:54am
Thank you for the stand advice, a bit of a way to get there as i just cut out most of the floor and still in the process of getting the unbelievable amount of foam out.. i have cut the floor abo type ut 3 inches from the actually gunwells and not exactly sure what the best saw to use to cut the fiberglassed in floor smooth off.. any advice on pulling the motor as well...either rent a forklift or built a swing set type over hang and hoist it out...not sure what composite yet, took a few pics and will do my best to load!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2012 at 9:54am
I suggest a engine hoist to pull the engine. They aren't that expensive and will come in handy with other projects. It will sve you the hasle of trying to build something yourself.
Most here have found a 4" angle grinder with a HF inexpensive diamond blade is great for cutting close to glass you don't want to cut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2012 at 11:54am
I agree with pete on the diamond blade, or if you have a rotozip they make a little 3 inch circular saw blade that works well. That is nice too because its variable speed.
I lifted my engine off a beam in my garage, I have seen people do it with a cherry picker but that is tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shane krausser Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2012 at 12:15pm
I actually have used an angle grinder to cut out the non-existing part of the floor so far, they are a bit scary getting close with just because they like to jump a bit, i did notice after pulling the foam out from underneath that lip of floor that is still attached that there is a bit of an ofset so it makes me feel a lilttle better about not going through the floor. I dont think there is any possible way a engine hoist would even considerably be tall even being im on the trailer and shes sitting about 6 feet in the air at the top of the motor, i would need atleast 12 feet to hoist her 1200 pound fat A** out!!! I thought of the beam but i dont have one and i cant even get in my garage with all the stuff!
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2012 at 12:20pm
You'd need a tall ceiling in your garage to get the engine out of a BFN and over the gunnel. You may want to get creative- search for a thread called "red neck engine hoist" for ideas. Heres what we came up with:
A 4.5" angle grinder with a diamond blade (cutting) and the most aggressive flap discs you can find (grinding) will be both your best friend, and worst enemy on this project!
A few of us have rebuilt these boats a few different ways. BuffaloBFN went the classic wood+foam route, as did The Grinch. Hasbeenskier went the composite route, using poly resin and some sort of foam cored material. We went epoxy and coosa on ours. There are a bunch of good threads, so do a bunch of searching and reading. I would highly recommend taking a lot of pictures and measurements before you get very far with the disassembly... figuring out where everything needs to go back together when starting with a clean slate can be challenging. Engine location (height and position in the boat) is especially important... I highly recommend taking measurements from multiple points, as one (or more) will inevitably change or move!
We also chose to leave the lip of the floor in place up until we got the stringers back in. It gave us a good place to rest the level and do a quick sanity check that things were getting put back together properly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2012 at 12:50pm
maybe it would make sense for you to take the wheels off the trailer and drop the boat down. I have seen people do this, you might be able to get it with a cherry picker then. "MIGHT"
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2012 at 1:38pm
+1 on leaving the lip around the edge, and rephrasing something Tim said-try to have 2 or 3 hard points to measure back to. He's right; some will disappear.
The picker will work but it's a pain. You'll have to pull the fender and wheels, drop the side, and it's still close. You'd also have to pull the near exhaust manifold so it doesn't hit the boom.
What's that new saw on TV? It looks like it might be the ticket for this except that it's electric.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote shane krausser Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2012 at 8:01pm
TRbenj, thanks for the photo, i have seen that picture on there which gave me that idea in my head about that type of hoist system, i am going to figure something out, do not believe im gonna go threw all the trouble talking the wheels off of my tandem trailer and chance it! I will need to take a lot of mearsure and i have taken some pics with my phone and camera and cant seem to even upload any on here cause its telling me they are to big and need to be resized..any help would be good with that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: January-04-2012 at 8:20pm
My local hardware store rents all sorts of tools, a chainfall being one of them. Find a big tree and go for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shane krausser Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 12:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote shane krausser Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 12:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 1:35pm
not too bad. To say that is not original, is an understatement!! What the heck is on that dash? Is that woodgrain? and a GPS?? You should put a cadillac emblem on that boat, that is luxury!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shane krausser Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 2:05pm
Haha lmao!! Yes that is woodgrain and it is smartcraft vessel view with gps, everything is computerized like a Cadillac!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 2:13pm
wow, I feel inadequate. Thats gonna be a luxurious model when you are done. Maybe you should put in a stained teak floor and some heated seats. Take this thing to the next level! Did you win pimp my boat or something!
Ranger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranger Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 3:12pm
I used a cherry picker and it was a pain. I would rent a fork lift or tractor if I was to do it again.
jeff
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 3:19pm
I cut glass with a pnumatic die grinder with a cutoff wheel, with a garden hose nozzle zip tied to it and aimed at the disk, small stream.
A little spray, but no dust. Just shop vac up the slurry afterward.
I think its the way to go.
Wear ppe of course
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote shane krausser Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 3:30pm
Thanks, ive been using the angle with the diamond, have all of the floor out besides where the fuel tank is, got most of that foam out last night, jeff im thinin a fork lift or tractor to, dont have any big trees or time to built a redneck hoist!!
tullfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 7:47pm
Shane
I test drove that boat last year in Mt Dora. It has a monster engine in it. If my memory serves me right, it's a left hand rotation. When I backed away from the launch, it went the wrong way. The dash pod is sweet. It's not a GPS though, it's the computer that controls the engine. I think that engine is only a few years old. We never got to run it through it's paces because it overheated. They guy later told me the pickup screen was clogged. For the short time it ran, you could tell it had some balls. Sounded great.
Did you find a trailer for it?
'85 BFN
'90 BFN
White Lake, Michigan
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 7:58pm
BTW
I was hoping whoever bought it would be on this site. I thought my engine looks huge, and so do most people who see it. That engine, and the added cooling system and other items, barely fit in the box (in fact doesn't it have a doghouse riser?) I'd like to know how it runs at top end.
'85 BFN
'90 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote shane krausser Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 8:22pm
Such a small world! Thats my boat, it is left hand. Yes your right it has GPS speed not nav. She runs great had a lot of trouble getting an acme on. Ive had her 57 with a 4 blade but i have bill at acme. Going to be making a custom prop.enjoyed it for the summer just wanting to do the last thing, the floor.lol, i did by a trailer from the original owner all aluminum tandum which is nice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shane krausser Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 8:24pm
And yes there is a riser on the dog house.
86BFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 86BFN Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 9:19pm
So do you foot? Or do you just like big motors and speed.
👣 Steve
89 Martinique
Former Owner: 93 Hydrodyne 350 MAG
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 9:24pm
said something about boarding in the first post
skifly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shane krausser Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 9:48pm
I do not foot....yet! Will be getting to that over summer hopefully. We do wakeboard though. I do like speed every now and then. Nice to have the leisure though. What about yourself??
Did you end up getting a boat??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2012 at 11:02pm
This is a good method,but due to the fact the left hand tree is dead it has a limited life span.It would take a lot of cpes to maintain it. The next best is to use a live tree. I think you should rent something,by the time you fix the boat,repair the engine and pay the medical bills you'll be ahead.
We never had to but we thought if we needed to change the engine on this one that we would just use the front davit
