  New Posts New Posts RSS Feed - 79SN Rebuild
79SN Rebuild
Dbat 79SN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dbat 79SN Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 6:49pm
Yes, I am doing the floor as well. Thanks for the quick reply.
Dave
Jllogan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 7:08pm
seems that two gallons is about where most guys end up. That left me some do to the inspection panel in the back and the wood pieces up under the bow, I used every drop.
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 10:03pm
Yep go for the 2 gallon kit. The first coat soaks up a ton. Each successive coat will require less. I did 3 or 4 coats and. Y the last one will barely soak in at all. Then you know it is saturated.
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2012 at 10:17pm
Originally posted by Dbat 79SN Dbat 79SN wrote:
I'm just about finished cutting and fitting the new stringers and wat to start priming them with CPES. I can't find any coverage area on any of the websites that sell CPES. Can anyone give me a clue as to how much I need to order to prime the primary and secondary stingers?
Dave,
Have you been looking at the existing threads on stringer replacements? they are an excellent source for what's needed. The big variable will be the moisture content of the wood you are using. What is it? have you checked it with the moisture meter??? The drier it is, the more CPES is sucked in!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dbat 79SN Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2012 at 11:09pm
I've been reading threads and doing reserch on epoxy vs. polyester resins for stringer replacement and I just don't seem to find a clear answer. The original boat was done with polyester resin, but it appears that there is quite a bit of differing opinions on which one should be used. Can anyone clear this up for me?
Dave
79TiqueRebuild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: February-28-2012 at 11:23pm
David, From what I remember when doing the research for my 79 sn rebuild, is that polyester is hydroscopic. Water will penetrate it. I used epoxy and was pleased with the results. I'm sure some of the experts will chime in. I am just a hobbyist but I hope that this helps. Monty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: February-29-2012 at 12:41am
My little experence comes from having an attached garage,epoxy does not smell up the house and keeps everyone happy.
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-29-2012 at 10:44am
Glass CC's were built with polyester resin until 1989. They were built with vinylester from '89-92 (AME4000). Since then, theyve used a vinyl/epoxy blend (AME5000).
Epoxy is the best of the 3 types- it does not absorb water. It is also the strongest, and its easiest to work with (easy to get proper mix ratio between resin and hardener, very low on fumes, no need to add wax to get it to cure, etc). Polyester is the low end in all these regards, vinyl splits the difference between the 2. Pricing per gallon is in the $30 range for poly, $40 for vinyl and $50 for epoxy. For a manufacturer, the difference in cost is significant when youre building a lot of boats (which is why most are built with poly). For a single boat rebuild, the cost difference for the small amount of resin required (10-15 gallons) is only a few hundred bucks... so it seems most people are willing to spend a little extra for the "good stuff" if theyre going to be investing 200+ hrs in labor for such a project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dbat 79SN Quote  Post ReplyReply Direct Link To This Post Posted: February-29-2012 at 2:18pm
Thanks for the input. Now I have the next question...what is the best epoxy to buy? Most of the epoxies that I have found are about $75-$100 a gallon and the one I have found some of the better reviews on is "System Three". Do you have a recomendation and a source?
Dave
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-29-2012 at 2:31pm
I, and many others here, have used US Composites with good results.
