  New Posts New Posts RSS Feed - GT40 takes longer to start when warm
 Post Reply Post Reply Page    <1234 6>
C_Heath View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 1:07am
Originally posted by lewy2001 lewy2001 wrote:
Fuel pressure is the best place to start after you have confirmed spark. One quick simple check is can you hear the fuel pumps prime when you turn the key to on position before you crank the engine. Adding a fuel pressure gauge to GT40 tool kit is the best $45 you will spend
Got one Friday.
1979 Calipso Runabout (the boat that got it all started)
1988 Mastercraft ProStar 190 (sold)
2000 Pro Air Nautique/GT40
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 11:17am
He's got a Chevy he uses all that stuff on. Used oil,filters and plugs are good enough for it. I do shake my head when I hear people changing plug wires just to change them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 10:12pm
Ok fellas. Here’s the fuel pressure test results.
Key on engine off: I charged the pumps and they started at 26. Five min later, 22. I didn’t wait any longer.
Key in engine running 32. 2000 rpm’s 31. Cut it off and it stayed 32. After 5 minutes she dropped to 28. After 5 more minutes 25
The high pressure fuel pump is brand new as well as the fuel filter in the FCC. Additionally, after i let it set for 20 minutes with the key on engine off, It wouldn’t start afterwards. I had to go wide open throttle and it fired. I guess it was flooded.
So thoughts? My reason for the test in the first place was long starts when the motor is warm. It has never failed to start on the water but a 5 second start was common every time after I cut the boat off.
I have not replaced the low pressure pump or the fuel pressure regulator or the injectors but those are coming. Boat is 20 years old. 604 hours.
Thanks for any input in advance.
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 10:49pm
Those pressure numbers are low 38psi + or - 3 is the spec.
Remove vacuum hose from fuel pressure regulator and check for any signs of fuel and recheck pressure readings.
I would also check the flow from your low pressure pump. This pump has a much higher failure rate than the HP pump.
You can disassemble this pump and check for blocked filter screens before replacing as I think Gary mentioned earlier in the thread.
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 11:16pm
I was going over page 41 of the GT40 manual and it said 31 + or - 3 was the standard. Shouldn’t the pressure be holding anyhow? Regardless of the standard I’m not sure if pressures supposed to drop after killing then engine or not ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 11:25pm
Follow this link to the reference section and read starting on page 2B-2 it will explain how the fuel pumps and injectors work. Then you can test it properly and report back.
Should be 39 +/- 3 when you first turn the key to on, LP should run for approx 2 seconds to prime HP canister. It should hold the 39 psi thru cranking.
At idle (not 2000rpm) it should drop to 31 +/- 3
Page 3H-2 is the trouble shooting for the leak down test
You will need to jump the fuel pumps for this test but rule of thumb is rail should hold pressure within 3psi for 3 minutes.
http://www.correctcraftfan.com/Downloads/Pro_BOss_GT-40_Service_Manual.pdf
PS; 20 years and 604 hours is a spring chicken on this forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 11:44pm
Ok I read it. It said if low goto 3H-12 and there wasn’t one lol. Regardless, I ordered a regulator last night and in the morning, I may go Ahead and get the LP pump and maybe even injectors with adapters. That will be about the entire fuel system lol but I don’t wanna be towed so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-14-2020 at 11:50pm
Before I went through all the work of changing injectors I would make sure that’s the problem.
And the 3H-12 is there its all the way at the end of the manual. Keep scrolling
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 12:03am
Ok lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 12:29am
Ok lol
I found 3H12!!!! Haaaa!
The more I read the more I think it’s the LP PUMP. I’m going to re test it tomorrow. For some reason I think that low reading at the beginning with key on motor off was wrong.
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 8:55am
Might be a silly question on my part but if the boat runs great all day, only acts up when it's been off for a while why do you think the LP fuel pump is causing this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 11:19am
one of the pinpoint tests referred to (replace LP pump) I think twice, I also think one or some of the injectors are leaking after shut down. Im a newbie tho.
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 12:01pm
That wasn't just for you, but for anybody who's been suggesting the pump
Now things that you know from the manual are that it should have
39+ or- 3 psi KOEO
31 + or- 3 psi at idle
When testing, the pressure drop should be no more than 3 psi in 3 minutes.
Due to the regulator it will run somewhere between the nominal 31 and 39 mentioned above while running around on the lake depending on engine load. The load affects vacuum, which is sensed by the regulator. This lets it maintain the proper pressure to maintain the same differential pressure across the injectors.
At full throttle there's basically no vacuum in the engine and your pressure would be around 39 psi
Why not hook up the gauge and take the boat for a ride making a note of how it starts cold and what the pressure was at KOEO and then again when idling.
Then drive it a while, park for your normal amount of time and watch the gauge to see what it is just before you're turning the key again and when starting
That's just for some real world numbers and info to go along with the manual test sections.
Post Options Post Options   Thanks (1) Thanks(1)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 12:03pm
I agree with Keno
If it runs fine at WOT it’s getting enough fuel. I think your problem is either the regulator, timing, or a leaking injector.
But first we need some accurate fuel pressure numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 12:16pm
I agree with Keno
Surely will do. Thanks.
I agree with Keno
Thanks gun,
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 7:29pm
Went ahead and replaced the new cap and button on the distributor. I had a brand new one so what the hey. I also re-tested the fuel pressure. Here’s those.....
Key on engine off 38. After 4 minutes it fell to 34 and after 12 min was still 32
Engine running at idle. 31. Stayed there the whole time.
Next is the timing light and fuel pressure regulator. I’m chipping at it one at a time. You guys are gonna have to lend me a hand on the timing deal. Never done it. I did find the sprout just now and I think I know how to get it to TDC. but as far as actually running the light. No clue lol. My harmonic balancer does have a timing Mark on it but it’s pretty Rusty. Lol
Thanks as always to the guys that has help. Gary, Keno, gun, jhersey and many more.
cboland View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cboland Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 7:56pm
Based on my experience, I’ll chime in on KENO’s question above regarding why a LP pump would cause an issue only after warm and sitting for a while.
Last fall I fought an issue whereby the boat would startup perfectly fine cold every time. After a good long run and then shutting down and sitting for a while, the boat would actually start up but then die about 1 minute later and I could not get it to start back up until sitting for maybe an hour longer. With key on, engine off I could hear both pumps prime, so initially didn’t think there was anything wrong with either.
Long story short, after fiddling around and hooking up a fuel pressure gauge, I found that when he boat wouldn’t start I was getting zero fuel pressure and when I pulled off the output hose from the LP pump, nothing was coming out. I guess once it had a chance to cool off by sitting it would start working again. I replaced the LP pump and have had no issues since.
So, while this isn’t exactly the same scenario the OP is having, the moral of the story is these LP pumps are strange birds. You might hear one power up, but that doesn’t mean it’s pumping fuel.
Bud
1999 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 8:30pm
I think that with those numbers, you don't have any injector leakage or fuel pressure regulator leakage issues that are causing your problem.
I think your issue and CBoland's are different but that's just me thinking. and like he said they can act strange.
You seem to have pressure and no running issues once it's started when warm, while his died completely and had to cool off
So after it sat for 12 minutes, was that after driving it around and duplicating your conditions of being at operating temperature and then you turned it off, did the check over the 12 minute period and restarted it. Did you have normal fuel pressure on the restart?
The only way to get normal pressure is with both pumps running together
Just out of curiosity what's your idle speed in neutral and also in gear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 8:38pm
Maybe you should update that thread from last year, here'a a link to it
Skip the part about pulling Pete around on a tube in a bikini though
Post Options Post Options   Thanks (0) Thanks(0)   Quote cboland Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 8:44pm
Ha. Thanks for the reminder. I’ll do it now. I’d still be interested in seeing what some of our photoshop folks can do with Pete in a bikini on a tube.
Bud
1999 Sport Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 9:00pm
Sounds like the challenge is on
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-15-2020 at 9:52pm
Thanks a bunch. For $79 on a new LP it’s for sure worth it. I just finished another test to make sure my novice mechanic skills were good enough and fired it after swapping out the rotor and cap. It did........But I went ahead and checked the fuel pressure while I was at it. 38 KOEO and 31 running. After I shut it off it went to 35 and stayed there while I unhooked the water and cleaned up. After 15 min it was still 35. That makes me feel better about an injector leak tho anything is still possible. Thanks again guys.
Post Options Post Options   Thanks (1) Thanks(1)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2020 at 4:45am
You have great advice above. You don't have any leaking injectors or your fuel pressure would fall off quickly. Yours does not it holds just like it should and you are in good shape as far as pressure bleed.
Leave your pressure gauge hooked up and verify you have full pressure when you try to start your engine hot after sitting.   If it still does not start promptly and you have 38-39 PSI you can rule out fuel supply as your issue. You can also rule out flooding due to injector leaks.
Did you clean your mesh screen which functions like a air cleaner/filter and fire suppressor.
If this is dirty you may be running rich with a hot engine making for the hard warm start.
On cold start when checking pressure I usually turn the key on 3 seconds, then off, then on again to see what pressure the pump is offering.   Sometimes one turn of the key does not hit max pressure.
Maybe your pressure relief valve is not working all the time and on your warm starts you are not getting the full 39 PSI. This was mentioned earlier in your thread but I am not sure it was actually checked.
I just read your thread and it sounds to me like you have a good fuel system supply and great advice already.
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2020 at 9:01am
Well at least the money you saved on injectors can be thrown at some other parts that might solve your issue or if nothing else you'll have a good spare parts collection.
Maybe you missed it earlier, but what's your idle speed in Neutral and in gear? (there's a reason for asking)
Post Options Post Options   Thanks (1) Thanks(1)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2020 at 9:38am
Pretty bored here so will do some kibitizing
Any possibility that the cold-start F/A ratio could be happening during hot start?
If so, maybe a temp sensor, wire, or even controller could be at fault.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2020 at 9:49am
That goes right along with the idle speed question
Aengenend View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Aengenend Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2020 at 10:29am
Quick dirty fix for the LP pump issue: pull the lid, rotate the vanes and reassemble. Dit it with ours and fixed it for maybe another 10+ years?
SN 93, Pro Boss HO, GT-40P, ACME 422
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2020 at 11:01am
by memory 650-700 in gear
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2020 at 11:02am
just went ahead and ordered a new LP pump. Thanks
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: April-16-2020 at 11:13am
Sounds normal
If your ECT sensor. ACT sensor or MAP sensor are reading out of range, a default value gets fed to the computer and the idle is set at 800 rpm by the computer.
I think like SNObsessed said, I'd be looking at sensors and the wiring to them and throwing money at sensors next. A sensor can be reading bad and not be out of range.
The only way to convince yourself that it is or isn't the LP fuel pump will be to change it
