pylon removal |
Jllogan
Platinum Member Joined: May-18-2011 Location: canton, OH Status: Offline Points: 1728 |
Posted: August-16-2011 at 2:07am |
If I remove the four bolts by the pylon will it come right out? Is there anything else holding it in?
KFD14
Senior Member Joined: September-07-2008 Location: Hailey, Idaho Status: Offline Points: 226 |
There is a bolt in the bottom of the pylon securing it to the bottom of the hull. After you remove that it should come out.
Jllogan
thanks!!!
dwcar
Platinum Member Joined: February-11-2007 Location: Houston Texas Status: Offline Points: 1103 |
If it has never been removed, you might have some corrosion down in that cup. It took me a while to get mine to come loose. Dont use the tow ring tow twist with. It is only brass and will bend with alot of torque.
83Ski
