71' Martinique Winter Stringer Project |
Post Reply | Page <123 |
Author | ||
Im not aware of any stringer jobs (at least not any that were done appropriately and documented on CCF) that simply installed new stringers without glassing them in... thats pretty much a given unless youre pioneering a new rebuilding technique. When people say "treated", they mean pressure treated (green) lumber. As Pete explained, CPES is simply a thinned epoxy resin. Being thinner, it wicks further into the wood than epoxy would by itself- so it essentially plasticizes the exterior surfaces. I think you have a little more reading to do on your bedding method as well. I would not recommend bedding with pure epoxy. The 2 most common methods are epoxy soaked mat, and thickened epoxy resin (with a high strength filler like milled fiber or aerosil-cabosil). Doing straight epoxy would be a runny mess, and not nearly as strong. I cant see your pictures, but hopefully the channels youre referring to have been trimmed down extremely low- 1/4" or less. Theyre more for a guide/work aid when rebuilding, and shouldnt be counted on for any strength. That will come from the new glass. |
Jllogan
Platinum Member Joined: May-18-2011 Location: canton, OH Status: Offline Points: 1728 |
Tim, He did say after he bedded them he would glass them in, in his original post. Also I assumed since he was pricing a thickener he would use thickened epoxy to bed, or at least after he poured a little out he would have come to that conclusion
Definitely use CPES, it should actually help with adhesion and it waterproofs your wood, but well thats been said. You can also get it from rotdoctor, whichever is cheapest. They make a cold weather and warm formula. I am using the cold as Im in ohio and its 25 out right now. I think since you are doing a wood floor you will need about 2 gallons. jamestown is 189.99 and rotdoctor is 195.48. Sometimes jamestown has free shipping too |
Metallman56
Groupie Joined: February-23-2005 Location: Indiana Status: Offline Points: 69 |
ok then. CPES will be added to my list. that makes sense i have read a lot of people using it, but always wondered why if the glass wasnt going to stick as well. that makes sense now.
i guess there is some confussion, i will be glassing in the stringers. before the stringer(s) go in though i will be putting expoy in the channels. not exactly sure how yet thought, this being my first (and hopefully only) time doing this. but yes both stringers will be reglassed. thanks again for all the help guys. after reading several threads they start to bleed together, and you dont remember which one is which, who did what, or how. i thank everyone for thier imput. and great catch on the CPES. :) |
Metallman56
2 gallons of cpes get ordered tonight or tomorrow. finally have the funds to kickstart the project again!!!
Metallman56
just ordered cpes from jamestown
FY!!!!! SHIPPING CODE FSHIP50 WILL GET YOU FREE SHIPPING RIGHT NOW FROM JAMESTOWN!!!!! UPS GROUND ONLY!!!! |
Jllogan
I have been experimenting with homebrew CPES and I have been pleased with the results. Just take epoxy resin and thin with around 50% xylene (from your local home improvement store). So if you run out, that could work. I ran out and didnt want to wait to get more in the mail. Also I used it for all above the floor applications such as the piece of wood in front of fuel tank, etc. Just an FYI.
Justin, Just a word of caution here. Tim did some experimenting as well as Roger over in England. I believe Roger went to the extent of digging up the MSDS on the CPES and found some pretty exoite solvents in the CPES. I have a feling they are used to make sure when the epoxy starts to "kick" you don't end up with solvent entrapment. I have a feeling the Xylene isn't "fast" enough. |
Jllogan
possibly, it is much less stinky anyways. This is why I used it on non fital above the floor parts such as that piece of wood and the kickpanel etc. I wouldnt use it on my stringers unless I was sure but so far it seems to be ok, it evaporated a little less slowly but I also probably didnt thin it as much as the CPES. I believe CPES is somewhere around 80% solvent. This may end up being more like a sealer.
Jllogan
I see your spelling improved. |
Ive done minimal experimenting myself, as I havent built a wood stringered boat in a while... but here's the link that has the "Home Brew CPES" info:
Penetrating Epoxies Pete, they did some experimenting on how long it took for the different blend to set up- the more solvent, the longer it took... but eventually everything set up. Even if it doesnt perform quite as well as the professionally mixed CPES, I would guess its better than not using any at all.. and at 1/4 the price, not a bad way to go. |
Jllogan
especially for non structural treatment.
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1423 |
The main solvents in the CPES are Toluene, Xylene and Isopropyl Alcohol. Not good for drinking. Take care,
Had good results thinning @75% Xylene and epoxy, Its always a personal choice over cost as Tim said. |
Lets have a go
56 Starflite 77 SN 78 SN 80 BFN |
Metallman56
i dont know about making CPES but its definatly on its way :)
Metallman56
wow i didnt expect getting the bottom angle of the stringer right would be such a pain. 2 days of filing it down by hand to get the correct angle and i'm not even done yet. only about a foot to go, ran out of time tonight.
once the angle is right, i have to cut out the cross members, and then cpes. my order from us composites should be in on friday. hopefully sunday i make leaps and strides, because i work 12 days straight after that. looks like some long nights ahead. my May deadline is starting to get painfully close, and i have a LOT of work to do. |
A cheap power hand plane for HF is what most use. |
Yup! That $30 cheapo tool will turn a 2 day project into a 2 minute one. |
Jllogan
yes I agree, that was one of the trickier parts. Its alot of fit and check thats for sure.
Metallman56
3 coats of cpes on stringer #1. waiting for it to cure. i definatly mixed too much, lol. once mixed, i wonder how long it stays good for when sealed. something tells me its not going to like it is suppose to after so long. i'm sure its going to go to waste which sucks. i thought it would be a lot thicker then it was. noob mistake, live and learn i suppose.
us composites came today. 8 boxes over 200 lbs. sweet. |
Metallman56
well finally got to work on the boat after a freaking month. god i hate my job. i'm quitting, so that will give me some more time in 12 more days!!
ok so cpes cured, and the stringer looks awesome. put it in the boat, and i'm about 1/2 high. didnt have time to measure it from front to back, so i'm relaly hopping its 1/2" down the whole thing. then i can just take an extra 1/2 off the top, re-cpes, and epoxy it in. warm weather really puts a fire under my butt. i really really want it to be done, cant wait to drive it. still hope it floats also i'm thinking, maybe muffleres wont make it back in. . . . .. maybe |
Metallman56
1 more question. from a lot of posts i have read most just skip over how exactly to put the stringers in correctly. maybe i am readying the wrong posts, but most of them just say "putting stringer in next" then theres just a pic of it back in. from what i can tell, most if not all use just straight expoy. put i really cant tell if 2"cloth goes in there as well. i also saw where keegan took too much wood off the back part of the stringer. everyone one said just use epoxy it will be fine. so a little advice there would be appreciated.
also one the stinger is back in, will the epoxy alone be enough to support the boat when i take out #2, or would it be wise to glass it in before #2 comes out? thanks again guys, and more pics and progress to come soon. with my new job comes not only nights to work on it, but weekends too. ahhh weekends, almost forgot what those were |
Jim,
Yes, you must be reading the wrong threads. The stringers are bedded to the hull with thickened epoxy that creates a fillet between the stringe vertical side and the hull. Then yes, you will want to do at least two layers of glass layup before you go to the other side. The only time you what to use just unthickened epoxy is with the glass layup. |
BuffaloBFN
FWIW-I also used a strip of mat under the stringer. It helped to hold the 'butter' in place and was intended to take up any minor gaps.
Metallman56
thanks guys
Metallman56
so today the final test fit of stringer #1 was complete. this was thanks to the power plainer i bought today. my god that thing works awesome for shaping the bottom of the stringer. i also applied more cpes to the bottom after we took off that extra 1/2.
tomorrow if the cpes is cured enough stringer #1 goes back in. i just want to double check that i know exactly what i'm doing before i put it in. first i'm going to put down the 2" glass i bought from u.s.c (FG-C02R). then i'm going to mix the medium epoxy 3:1 and carfully put that on top of the 2" glass. next in goes the stringer. followed by heavy objects on top to make sure stringer does not move. seems pretty straight forword but i want to get this right the first time. if i'm missing something please post, and please feel free to talk to me like i've never done this before. |
Jim,
At this point it sounds like you are doing a great job but, some pictures sure would help us. You know that old saying! |
Metallman56
sadly i do not have any pics right now. and by the time i can post some tonight stringer #1 will already be in, hopefully.
i guess what i'm looking for is a detailed step by step how to on putting a stringer back in the boat. this is the one thing i dont want to screw up. it seems to me getting a stringer out that has been set in with expoy would be about 10x harder then taking out the original stringer. so i just want to make sure its done right the first time. thanks again for all the help! |
Metallman56
something came up last night and stringer #1 didnt go in. i was however able to get a pic. its from a camera phone, and its dark so sorry for the poor clarity.
no stringer in yet, just wanted to double check how exactly it is suppose to go back in. |
Jim,
From the picture and without a better description, I can't tell what the problem is. |
uk1979
Jim, Have you ground off the old gel around the stringer as the picture looks like its still there from over the pond ?
Lets have a go
Yes! I had to run to a meeting so I couldn't spend much time looking at the picture. Roger is correct - the glass on the hull next to where you are bonding the new wood in needs to be ground down. You need to get the bilge gel coat off and get to some decent glass. Jim, Have you been able to go through some of the other stringer replacement threads? Plenty of pictures and great info. Still, do keep the pictures and any questions coming our way. |
